Optima Alarm Panel
B
Brett
Hi , I have just moved into a new home and have the former owners hav
not left the correct alarm code for the system (Optima, not sure o
model). Is there a way to reset the system so that I can enter a ne
code. Thanks in advanc
Jumpster Jiver
Brett said:
Hi , I have just moved into a new home and have the former owners have
not left the correct alarm code for the system (Optima, not sure of
model). Is there a way to reset the system so that I can enter a new
code. Thanks in advance
You should call the former owners and ask them, or call the alrm
monitoring company.
The company's phone number may be on a sticker on the alarm circuit box.
THe box is probably in a closet or the basement.
H
Homer J Simpson
On some models if you have the key to the main box you can disconnect the AC
power, open the box and pull the battery leads. The alarm will sound until
the battery leads are pulled. After a while it should reset to the default
code, or there is a jumper that will reset it.
Get the manual for the panel and some advice on this model.
http://www.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=12934
