optical isolation
Discussion in 'Electronic Equipment' started by Riccardo, Sep 30, 2003.
  1. Riccardo
    Riccardo Guest
    Hi all, anyone knows if it's possible to isolate (in optical way) a
    single wire or a couple of wires?
    It should be something that I can put on my PCB and on one side there is
    the IN-wire (comes from outside), and as output I've a wire that is
    isolated optically.
    Riccardo
  2. yes, if your signal has enough power to drive the led of an optocoupler.
  3. FSMüller
    FSMüller Guest
    sevral questions: is there electrical power to be transferred or is it
    only signals? uni- or bidirctional?
    if its unidirectional signals and the frequency is not tto high (<
    100kHz), you should consider optocouplers, they come in lots of
    varieties and packages, try googling for IL74 or 4N26, there are duals
    and quads too (ILD74 and ILQ 74 respectively) the datasheets you find
    show how they should be connected.
    greetings
    Frank
