Operational amplifiers
Discussion in 'Electronics Homework Help' started by Mbetts, Feb 22, 2013.
  1. Mbetts
    Mbetts
    4
    Feb 22, 2013
    Hi guys I recently started a degree in electronic and electrical engineering I come from an advanced apprenticeship background and I'm not the best mathes student.
    My lecturer gave me the worksheet pictured.
    I used the formula as follows for calculating inverted and non inverted amplifiers.
    Inv: Vo R2
    Vi R1
    Non-inv: Vo R2
    --- = 1 + ---
    Vi R1
    I transposed the inverted op amp formula and got all the answers right. Got onto the non-inverting op amp and got most of the answers right except the R2 ohmage. Do you think this is his typo or am I wrong (I'll put my thought process down.)
    (Vo )
    (--- - 1) X R1 = R2
    (Vi )
    With this in mind.
    (11.75 )
    (------- -1) x 1000 = 46k
    (0.250 )
    Any help or guidance is greatly appreciated also any sites and books I could read?
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    R2=46K is the correct answer. But how can you be sure?
    Look at the schematic for the non-inverting amplifier. Realize that whenever an (ideal) op amp is in its linear operating range the voltage at the '+' and '-' inputs has exactly the same value. Here the voltage at the '-' input is the result of a voltage divider from Vo so the equation V'+'=V'-' gives 0.25=11.75(1/(1+46)). You know your answer is correct if 11.75/47=0.25
  3. Mbetts
    Mbetts
    4
    Feb 22, 2013
    Thanks for the reply.
    You are the second person to have confirmed this for me I used stand the op amps input works with the output the create a ratio that gives the output when working Vo anyways I understand a bit better now,
