OpenOCD JTAG
Discussion in 'Microcontrollers, Programming and IoT' started by saripitu, Aug 2, 2011.
  1. saripitu
    saripitu
    26
    Jul 12, 2011
    Hello, I am trying to install the new Olimex ARM-USB-OCD that I have bought but for some reason its giving me errors. I got the FTDI drivers and installed them:
    cd libftd2xx0.4.16
    ./configure
    make
    sudo make install
    Then I installed OpenOCD:
    cd openocd-0.1.0/
    ./configure --enable-rlink --enable-ft2232_ftd2xx --with-ftd2xx-linux-tardir=../libftd2xx0.4.16/
    make
    sudo make install
    Then I made a udev file since it was what one of the webpages suggested:
    sudo nano /etc/udev/rules.d/45-ft2232.rules
    With the content:
    BUS!=“usb”, ACTION!=“add”, SUBSYSTEM!==“usb_device”, GOTO=“kcontrol_rules_end”
    SYSFS{idProduct}="0003", SYSFS{idVendor}=“15ba”, MODE=“664”, GROUP=“plugdev”
    LABEL=“kcontrol_rules_end”
    /etc/init.d/udev reload
    Then I tried to run it:
    sudo openocd -f /usr/local/lib/openocd/interface/olimex-arm-usb-ocd.cfg -f /usr/local/lib/openocd/board/stm32f10x_128k_eval.cfg
    And I am getting :
    Open On-Chip Debugger 0.1.0 (2011-08-02-12:30) Release
    BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
    $URL: https://[email protected]/svnroot/repos/openocd/tags/openocd-0.1.0/src/openocd.c $
    500 kHz
    Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
    Info : JTAG Tap/device matched
    Info : JTAG tap: stm32.bs tap/device found: 0x16410041 (Manufacturer: 0x020, Part: 0x6410, Version: 0x1)
    Warn : no telnet port specified, using default port 4444
    Error: couldn't bind to socket: Address already in use
    How do I solve this? Have I done something wrong? I am quite new with this so any help is welcome! Thanks!
  2. saripitu
    saripitu
    26
    Jul 12, 2011
    Hehe, I just found the solution, I had to change in stm32.cfg the flash bank to flash bank stm32x 0×08000000 0×20000 0 0 0
  3. saripitu
    saripitu
    26
    Jul 12, 2011
    Hi again! I manage to get the same error as before and now I cant solve it...any ideas?
    [email protected]:~$ sudo openocd -f interface/arm-usb-ocd.cfg -f target/stm32f1x.cfg
    Open On-Chip Debugger 0.5.0-dev-00973-g0d7a948 (2011-08-05-11:08)
    Licensed under GNU GPL v2
    For bug reports, read
    http://openocd.berlios.de/doc/doxygen/bugs.html
    Info : only one transport option; autoselect 'jtag'
    1000 kHz
    adapter_nsrst_delay: 100
    jtag_ntrst_delay: 100
    cortex_m3 reset_config sysresetreq
  4. ikansw
    ikansw
    4
    Aug 8, 2011
    The error is "Error: couldn't bind to socket: Address already in use" and it is complaining of TCP port 4444 being occupied by some other program. Your solution is to find that program, stop it, wait for the port to quieten down and be free again, or alternatively change the configuration (the cfg file, by specifying a "telnet_port" directive within) to use another port which may be free.
    A useful command to diagnose further is:
    netstat -antp | grep 4444
    If port 4444 is being grabbed by another instance of openocd you will come to know.
    Good luck :)
  5. saripitu
    saripitu
    26
    Jul 12, 2011
    Thanks Ikansw! i tried the netstat -antp | grep 4444 and all I get is
    [email protected]:~$ sudo netstat -antp|grep 4444
    tcp 0 0 0.0.0.0:4444 0.0.0.0:* LISTEN 1635/openocd 7
    is that bad??
    If i turn the laptop off for more than 10 seconds it allows me to run it once and I get:
    1000 kHz
    Info : clock speed 1000 kHz
    Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
    Info : JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
    Info : stm32.cpu: hardware has 6 breakpoints, 4 watchpoints
    and it stops there...any ideas what that could mean??
    Sorry i am very new to openocd and olimex!!
    Thanks again!
  6. saripitu
    saripitu
    26
    Jul 12, 2011
    Now, when i try to compile to program into the board i get this:
    1000 kHz
    Info : accepting 'telnet' connection from 4444
    target state: halted
    target halted due to debug-request, current mode: Thread
    xPSR: 0x61000000 pc: 0x08005534 msp: 0x200013d8
    invalid command name "quit"
    Info : dropped 'telnet' connection
    Error: ftdi_write_data: usb bulk write failed
    Error: couldn't write MPSSE commands to FT2232
    Polling target failed, GDB will be halted. Polling again in 100ms
    Polling target failed, GDB will be halted. Polling again in 300ms
    Polling succeeded again
    Any ideas what can I do now?? What kind of info would you need to solve this?? Thanks again!
  7. kld_555
    kld_555
    Nov 16, 2011
    How did you get it to pass the "Info : stm32.cpu: hardware has 6 breakpoints, 4 watchpoints" stopping problem?! mine stops there as well!
