Open source Logic Analyser
Discussion in 'Hobby Electronics' started by Craig Rodgers, Jun 27, 2003.
  1. Hi all.
    I have recently found myself in a position as, I'm sure many of you that
    have worked with embedded systems have, where a logic analyser would be of
    great advantage to debugging my projects. I have now come up agains a couple
    of situations where my CRO just won't cut it.
    Unfortunately I am not able to afford a DSD oscilloscope or a commercial
    logic analyser. My requirements are much lower then most of the commercial
    logic analysers I've come across anyway, I'm looking for something that can
    handle a maximum frequency of about 20~40 MHz.
    I've decided that I'd like to try and make my own, at the moment I'm
    planning a modular architecture based around 74F serries logic and a mcu.
    The plan at the moment is to have a control module that is responsible for
    interfacing the capture devices to a computer for display. And have up to 8
    capture modules (of 8 bits each) that interface to the a 3.3/5V circuit
    under test. Also I'd like to try and keep the cost of each module to less
    then $100AUD.
    I am aware of a design that was published in Elector electronics some months
    ago. It was lacking one particular feature that I deem as essential in any
    logic analyser. That is the ability to set trigger conditions based on input
    conditions, a feature I plan on implementing in my design.
    Obviously this design is of a "one-off" nature for myself. I feel that this
    is the sort of project that would be of interest to many people involved in
    embedded systems at a hobbyist to semi-professional level. So I am
    considering a open hardware type approach to this project so that other
    people can partake, and I dare say I can learn something from the
    experience.
    Which brings me to the point of this post. Does anyone know of a good
    sourceforge type site for open hardware development. I was aware of
    openh.org but they seem to have disappeared off the face of the internet.
    Also I was hopping to gauge the level of interest in people, would anybody
    in this newsgroup be likely to use such a product if it was developed.
    Regards
    Craig Rodgers
  2. Gary Pace
    Gary Pace Guest
    Craig ,
    This isn't really an answer to your question about open-source hardware,
    rather an idea of a way to get your logic analyzer.
    Consider using an FPGA.
    Altera Cyclone is an excellent part for this:
    The EP1C6Q240 has :
    4 dedicated clock lines for sampling
    Loads of IO
    4 IO banks, each of which can operate from different voltage levels
    Embedded memory arrays for waveform storage
    Lots of embedded logic / latches to create complex multi-state triggers
    Free development software
    One thing that might be a pain is that it isn't directly 5v tolerant, but a
    few 5v tolerant low voltage buffers isn't much of an overhead.
    Gary.
  3. kryten_droid
    kryten_droid Guest
  4. kryten_droid
    kryten_droid Guest
    http://panda.bg.univ.gda.pl/~janusz/software.html#anlog
    "The analyser consists of up to 40 TTL channels, connects to a host PC via
    parallel printer port and is capable of capturing data at a frequency of up
    to 50 MHz (external, and 16 internal frequencies). The trigger word can be
    set to any combination of "Low", "High" and "Don't care" states. In
    addition, a preset number of Triggers and samples after the final Trigger
    can be specified. The Logic Analyser buffer is 2048 samples wide."
  5. mike
    mike Guest
    Logic analysis is one of my favorite rant topics, so buckle up.
    What do you mean by 20-40 MHz? If you mean state analysis of a system
    that has states that can change every 25 ns, you have one set of
    problems. If you mean you want to look for timing problems on a system
    that changes state every 25 ns, you have a different set of problems.
    If you want to do it with affordable hardware, ie hardware that's only a
    few times faster performance to what you're debugging, plan on
    pipelining your word recognizer.
    A LOGIC ANALYZER IS USELESS IF YOU CAN'T TRUST IT COMPLETELY!!
    Channel skew will drive you buggy. You wanna build 64 channels spread
    across 8 cables and keep the skew low. Getting the signal from the
    source without loading it and with well defined notions of 1 and 0 and
    without adding skew and crosstalk and, and, and is a VERY difficult
    problem. This was 20 years ago at Tektronix, we got to
    10 MHz, just barely, by using ribbon cable with a ground plane along the
    whole length. The higher speed stuff used lots of twisted pairs in a
    round cable. Remember that typical cable is made by running one wire
    down the center and twisting the others around it. This is DISASTER
    for a logic analyzer. You need special cables.
    There's an interesting technique that revolves around a FPGA. You
    compile the trigger recognizer state machine on the spot and download
    it to the FPGA. Years ago, when I approached FPGA vendors about the
    subject, they flatly refused to disclose how to program their parts.
    More recently, there's a commercial analyzer on the market that appears
    to work just that way. Don't remember the name, but they sell 'em at Fry's.
    I built a probe hooked to a socket, programmed a GAL20V8 as a word
    recognizer and used that to trigger my scope or simple LA that had
    insufficient trigger capability. Was a pain to program each time, but
    I was able to do things I couldn't do otherwise.
    I've found that most problems where you're in control of the design fit
    into two categories.
    1) you can make indirect measurements and determine the source of the
    problem logically.
    2) It's very complex and intermittent and even the best LA won't help
    you. ie debugging the innards of a CPU.
    Yep, there are situations in between where a good LA will help, but as a
    percentage, it ain't much.
    And there's always that ole chicken-egg problem. It takes a logic
    analyzer to debug a logic analyzer design.
    I could go on for days, but I'm tired.
    Bottom line:
    If your time has any value, go buy a used logic analyzer. Make sure it
    comes with probes.
    If you're just in it to build one and don't really care if you can trust
    it, go right ahead and have fun with it. Start with the biggest FPGA
    that you can afford the tools to program. Choose your glue logic family
    from those who's 0 and 1 propagation delays are the same.
    mike
    21' RV, 400cc Dirt Bike
    Police Scanner, LCD overhead projector
    Tek 2465, ham radio, 30pS pulser
  6. I had actually given the idea of an FPGA based design some thought. I would
    love to be able to be let loose on an FPGA, I think I've got enough VHDL &
    Verilog under my belt to give it a decent go.
    But getting access to the synthesis tools always seems to cause issues. The
    "free" ones from the manufacture always seem overly crippled.
    Also, this one seems to be something that I've missed along the way, how the
    F**k do you program the buggers once you've synthesized your design. I think
    that the old school PLD's from Xilinx etc used to require an external EPROM
    to store the binary mask in. I think the manufactures finally started
    providing Flash based ones but I've got no idea how you'd go about actually
    downloading the mask to one with out requiring some expensive programmer.
    FPGA's at the moment seem too expensive, the per component cost is high, the
    cost of development tools is large. And the price of the development boards
    I've seen is some what excessive.
    If I do this project I'd like to do it in such away that it affordable and
    accessible for almost everyone. I think that means I'm going to have to
    accept some loss of flexibility and stick to readily available components. I
    feel that 74F series components are probable the most widely available set
    of components suitable for the job. May be I'm wrong I'd love to hear
    suggestions, particularly those regarding free/low cost FPGA development
    tools
    Craig
  7. Logic analysis is one of my favorite rant topics, so buckle up.
    More analysis of a system that can change states upto each 50ns or so.
    I realise that in reality I'm dreaming if i think i can pick up glitches a
    magnitude smaller in a system at this speed using off the self components.
    agrred, and so long as you realise the limitations of your equipment I feel
    you should be able to trust it.
    Thank you this is an area I hadn't thought about. Clearly I'm going to have
    to give it some more thought particuarly channel skew. Although I was under
    the impression that most of the twisted pair cables aroung today were of a
    resonable quality. Surely if I can transmit Gbs down CAT 5 even taking into
    account the pulse shaping to help limint the ISI then it's not unreasonable
    to
    think i can recieve 20MHz signals down a similar twisted pair with minimal
    cross talk problems..
    May be a suitable alternative for me at the moment.
    I don't expect a logic analyser to be a magic bullet in any circumstances.
    I do expect to get some time savings from it from not having to repeat
    the fault condition every 2 minuets in order to take another reading.
    if I could i would.
    Thanks for the tip.
    Craig
  8. Brett
    Brett Guest
    Atmel still has external eeprom type-fpgas I think. I have a few I never
    used.
  9. Gary Pace
    Gary Pace Guest
    Altera's web edition of Quartus II software is free, and is pretty much full
    featured - the limitations are in devices supported (i.e not their screaming
    high end Stratix devices) and there are no third party synthesis/simulation
    tools bundled (Altera's native ones seem fine to me)
    The EP1C6Q240 is around USD 24 in development quantities, and Altera have a
    low cost serial FLASH configuration device (don't know what low cost means
    in practice) that can be JTAG ISP'ed using a cheap ByteBlaster parallel
    cable.
    I don't know about evaluation boards and device programmers - Altera's
    website lists Cyclone development kits down to USD 500.
    I hadn't used an FPGA for 10 years, but I just completed a design with the
    above part and it was a breeze.
  10. Brett
    Brett Guest
    Except no documentation...
  11. Alex Gibson
    Alex Gibson Guest
    look under projects on avrfreaks.
    also you will find a few searching on google.
    for a logic analyser have a look at www.rockylogic.com.
    I have an ant8. Works very well for circuits under 100MHz.
    for fpga.
    may want to have a look at actel. have a flash based fpga so you
    don't need a eeprom or data flash to store
    your bitstram in.
    also have a look on opencores.org
    Alex
  12. Alex Gibson
    Alex Gibson Guest
    no much help in your not in the US.
    Note the op's email address .au = Australia.
  13. Markus Zingg
    Markus Zingg Guest
    [snip]
    So what? Look at my e-mail address ( .ch ) which means Switzerland. I
    bought 3 scopes and 4 analyzers for me and others from e-bay.com (i.e.
    from the US). Ok, I had ot add ~$120 shipping but considering the fact
    that you then get working systems which you can trust and that you are
    not faced with X hours of developement time trouble etc. etc. made it
    very worthwile. I haven't regretted yet a single purchase yet. Ok, if
    the original poster does this for the fun of it and for learing
    without pressure of having an analyzer to complete a task etc.
    building his own might be the right decission - otherwise e-bay is
    really a good option.
    Just my 2¢ though
    Markus
  14. Hi Craig,
    You may be interested in my old design that was published in
    Electronics Australia many years back:
    http://electronics.alternatezone.com/pcla.htm
    Seriously, forget 74F series logic and go for a PLD/FPGA based design.
    Interface to the PC via USB.
    This has already been done here with the ANT-8, but it's not open
    source:
    http://www.usb-instruments.com/hardware-ANT8.htm
    Bit expensive at over $300AU though.
    Regards
    Dave :)
  15. David Milne
    David Milne Guest
    Check out Bitscope.
    http://www.bitscope.com/
  16. Hi Craig,
    While it is possible to do a logic analyser with 74F/AC series logic,
    it's a logistic nightmare, and no one will be interested in building
    it, even if it's got supposedly "easy to get" 74 logic.
    Trying to do fully maskable triggering, with 8 bit busses running
    everywhere, skew, timing, buffering, storage/retrieval, latching, all
    across dozens of channels is a big pain in the ass from a PCB
    perspective. You'd be talking dense 4 layers boards, and the cost of
    those would more than offset the cost of going the PLD/FPGA solution.
    It would also be physically BIG, and if you were to go to a modular 8
    channels per card approach, you'd have to sort out motherboard
    mounting, bus interfaces and many other issues. It's ugly, don't do
    it, you'll regret it.
    Many of the FPGA/PLD vendors have free tools available, even if they
    are limited. Lattice and Atmel also have suitable FPGA/PLD solutions.
    If you have to pay much for software/hardware to do FPGA/PLD then you
    are going about it the wrong way. Flash devices are serial JTAG
    download, and you can often build your own serial cable from info
    available on the net. Same for the other FPGA, but they serial
    download into an external Flash or EEPROM device.
    A logic analyser is not complex, so you don't ned anything super
    fancy, a low level PLD will suffice, perhaps even one per 8 or 16
    channels. That way you can stick to easy to use packages. External
    SRAM is cheap and easy, use cache RAM from old PC's, they can be had
    for FREE!. Using SRAM in an FPGA might seem neat, but it pushes up you
    FPGA complexity curve and you are looking at big QFP or BGA packages -
    yuk. Once again, not many enthusists are going to touch that, in fact
    I'd be willing to say none.
    The biggest issue with logic analysers though is probing, as others
    have mentioned. It's complex, and there is no easy solution to it.
    It's a major reason why DIY logic analysers are not, and never will be
    popular.
    Regards
    Dave :)
  17. Well I've been convinced. I think that a PLD based approach is probably a
    reasonable one to take. The cost of the FPGA's themselves seem to have
    dropped significantly since I last checked them. I'm off to start comparing
    the synthesis tools from a few different vendors.
  18. Hi!
    Thanks for the description. You surely pointed out a number of problems. How
    about this approach: put all the high-freq part of the LA into an FPGA, put
    a small uC/DSP by side of it, fix the whole thing up with a USB/Ethernet
    port and stuff the whole thing into the box of the POD of a usual LA. The
    cable length would be < 10cm (4 inches) in that case, the channel number
    whould be 8-9, but definitely under 16. More of these could be connected to
    a PC and be grouped into a wider virtual analizer. Triggering over multiple
    PODs like this would be hard though...
    Regards,
    Andras Tantos
  19. me
    me Guest
    I'm not sure why all the problems, we've got cheap ($1200) Tek scopes that
    work great for the engineers in debugging those frequesnecy ranges. Is there
    a specific problem that you need solved so you can avoid the hassle?
  20. rickman
    rickman Guest
    On the Coolrunner parts you need to be aware that the chips are only "4
    volt tolerant" until power is applied. I don't know how robust these
    parts will be considering that they don't really stand up to 5 volt
    signals when not powered. You might be better off with a part with true
    5 volt tolerance like the SpartanXL (I think) or the ACEX 1K. From the
    ACEX data sheet, "Signals can be driven into ACEX 1K devices before and
    during power up without damaging the device. Additionally, ACEX 1K
    devices do not drive out during power up."
    Rick "rickman" Collins
    Ignore the reply address. To email me use the above address with the XY
    removed.
    Arius - A Signal Processing Solutions Company
    Specializing in DSP and FPGA design URL http://www.arius.com
    4 King Ave 301-682-7772 Voice
    Frederick, MD 21701-3110 301-682-7666 FAX
