Open-circuit Req Circuit
Discussion in 'Electronics Homework Help' started by Jermgilbert, Sep 10, 2020.
  1. Jermgilbert
    Jermgilbert
    4
    Sep 10, 2020
    I need assistance with this problem. I cannot seem to figure it out.
  2. Jermgilbert
    Jermgilbert
    4
    Sep 10, 2020
    I have tried to put it into LTspice, but cannot get it to run. I have tried grounding the open circuit ends, but that doesn't seem to work.
  3. Harald Kapp
    11,513
    2,651
    You need one single ground only. Using multiple grounds will short circuit these parts of the circuit. Show us your LTSPICE diagram or upload the .asc file for inspection.
    Provided you get the simulation up and running: how will you determine the equivalent resistance from the simulation?
  4. Jermgilbert
    Jermgilbert
    4
    Sep 10, 2020
    Could I add a resistor at the end of the wires and find the total resistance that way?
  5. Harald Kapp
    11,513
    2,651
    No.
    What is the usual way to determine the resistance of a component? Hint: what is the equation for R = ??? in terms of voltage and current?
  6. Jermgilbert
    Jermgilbert
    4
    Sep 10, 2020
    Oh, alright I could insert a voltage source.
  7. Harald Kapp
    11,513
    2,651
    Good. Where? And what's next?
  8. Ratch
    Ratch
    1,093
    334
    Mar 10, 2013
    Ridiculously simple. Redraw the circuit.
    Then use any generic equation solver or pencil and paper to solve the loop equations with a 1 volt source.
    1 volt gives 1/25 amp so the resistance is 25 ohms.
    Ratch
