Better than that here's some 'scope shots!
So I’m looking at avalanche breakdown voltages with different quenching
resistors (100k and 10 k) the first two ‘scope shots are with the
opa2134 100k ohm
//bayimg.com/MaoKGaaEA
10k ohm
//bayimg.com/NAoKDAAea
Oh and here’s the TLE2142 with 10 k ohm //bayimg.com/nAOKGaaEa
And now the opa2604 first 100 k
//bayimg.com/naokHaAEa
and 10 k
//bayimg.com/naOkjaaea
This is before I added a 50 ohm series resistor. That gave the bumps a
longer period but a bit higher amplitude.
Hmmn, just noticed that the GBW of the TLE2142 is about 1/4 of the OPA2604
GBW. That might be part of why you see the problem with the OPA but not the TLE.
The 'ring', after all, is near the unity-gain BW of the TLE. And you only
see the problem with some length of coax attached? Does it occur with no coax,
just probing with a good low-Cin 10x or FET probe? Could you plug in a much faster
amplifier while temporarily running at a lower voltage to see if there's a problem
with your circuit or its implementation?
If you really like the TLE2142 - how about compensating for the input bias?
Yes, it would cost a tweak.
Grin.. well PhD's are often less of the 'hand's on' type. But the
circuit is pretty easy. I made it through hole, so if someoen wanted to
change things it would be easier.
http://bayimg.com/PAoKiAaEa
The ugly pot in the middle will go away. (just changing the supply
voltage.) I let it cook over night at ~100C. no issues in the morning.
Ok, that seems simple and your users are presumably knowledgeable about
antistatic issues, etc.
I'll test the heat again with lower supply voltage (but with the palstic
cover in place.)
So what type of PhD's do you service? Can you tell us where you work?
George H.
Ah... the devices we design and build are for a collection of neuroscientists.
Many have some electronics skills but most of them have enough on their
minds trying to understand and/or manipulate the brain.
