John Popelish
Winfield said:Our 2ppm may well be coming from the caps.
Down at 2ppm, I would start worrying about resistor
linearity, also.
It largely depends on the excursion of the cone, which is higher at low
frequencies. Can be anywhere from ~10% at low to 0.1% or so at the middle
to high frequencies. For the speakers, the IMD is much more
representative parameter then the THD.
I still wonder if sending e.g. 100 Hz and 5 kHz at the same time to a
speaker wouldn't give a 100Hz FM modulation of the 5 kHz tone (doppler
effect caused by the cone movement).
But maybe the microphone has an inverse effect?
MooseFET said:MooseFET wrote: [...]
=== C1
Control-->! !
!-- === C2
GND GND
helps.
It divides down the amplitude the JFET sees and C2 also tends to short
out the harmonics.
Cute--that's like tapping a varactor down on a tank circuit. With an op
amp it isn't hard to know the total range of gains you can have, so you
can use a vernier control and get better nonlinearity.The down side is that the frequency of operation is more sensitve to
component values. BTW
That's because the phase shift depends on the control voltage. If you
used two resistors instead, you could get the same effect, minus the
couple of dB worth of harmonic rolloff, and no significant phase shift.
linearity, also.
Arie said:...
But then, what about a pressure sensor as microphone (assuming no diafragm
movement)?
"Vladimir Vassilevsky"
** No point in testing a multi-way speaker ( ie the vast majority ever
sold) for IM distortion.
The famous Quad ESL63 electrostatic speaker has THD in the order of 0.03% at
97dB SPL.
"Phil Allison"
How can that be measured?
Do you believe the number?
"John Larkin"
** Huh ?
No idea how THD can be measured ?
** No faith required, it ain't religion.
No idea of how to measure THD in a sound wave to this sort of
resolution. Are microphones this good?
If so, how do people measure *them*?
A lot of audio stuff seems to be.
Clifford said:Joerg wrote:
Rich Grise wrote:
How does booze "[go] bad"?
No idea but...
Actually I think Rich was asking how the booze doesn't get
consumed immediately it's in your possession, instead being
kept for long enough for *anything* else to happen to itWell, visitors mostly drank it. Before leaving Europe for good we did
throw one heck of a good-bye party for neighbors and friends but they
all wanted beer and wine.
Vodka, brown sugar, and seltzer tastes just like root beer. ;-)
Cheers!
Rich
John said:No idea of how to measure THD in a sound wave to this sort of
resolution. Are microphones this good? If so, how do people measure
*them*?
A lot of audio stuff seems to be. It sure ain't science. Do you
believe that you can buy cables that are six-nines pure copper?
One method is to assume that the microphone is time-invariant at small
amplitudes, pick a repetitive signal, and do a lot of signal averaging.
By attenuating the sound with distance, the distortion polynomial
(i.e. the Nth harmonic goes as amplitude**N for small amplitudes) allows
you to distinguish between microphone and speaker distortion.
Not too much fun, but conceptually not too bad.
I believe that some are _advertised_ to be six nines...of course that's
before they went through the drawing die, not to mention the oxidation
due to using thin strands...even assuming that people who would stoop to
fleecing audiophools have the elementary honesty to _try_ to deliver six
nines wire.
nines wire.
What sort of harmonic distortion does a speaker have? I've seen
numbers like 6% called "good."
I'd imagine that most capacitors add distortion, too.
An analog multiplier is the obvious choice.
On Feb 5, 1:23 pm, John Larkin
Obvious, but not nearly as linear as a cheap photocell or light
bulb . And nowhere near as economical!
The fact that the gain of a light bult or photocell can vary by a
factor of a few depending on room temperature or recent light history
etc. is not all that important if you're searching for ultra-low
distortion.
I also suspect that dielectric constant varies a bit with electric field
due to electron orbits in the dielectric's molecules being squished out of
shape. I expect that effect to be mitigated by use of a thicker
dielectric (higher working voltage).
Some ceramic capacitors have dielectric constant so high that I would
not trust the dielectric constant to be all that constant. This is
probably worse with ones whose dielectric constant varies too much with
temperature anyway for the capacitor to be useful to make a good
oscilltor.
distortion.
Tim.
