OpAmp Input Stage with different voltage ranges
Discussion in 'Electronic Design' started by Marco T., Jul 27, 2006.
  1. Marco T.
    Marco T. Guest
    Hallo,
    I must develop a system that should accept at the input the following
    voltage ranges:
    0 5v
    0 10v
    0 15v
    I thought two chances:
    1) Using a voltage divider where I could choose the couple of resistor using
    2 multiplexer.
    I connect every resistor to input of a mux and I configure the two mux using
    a couple of jumpers.
    Then I connect to oupt of voltage divider a opamp voltage follower or
    similar.
    2) Using a programmable gain amplifier.
    There are orther chances?
    Any comments is very appreciated.
    Many Thanks
    Marco
  2. Marco T.
    Marco T. Guest
    I forgotten to say that output stage must be in range 0 5v.
  3. mmm
    mmm Guest
    If you want to use jumpers to configure the mux just remove the mux and
    use jumpers to configure input topology ( or even place only needed
    resistors )
    input
    o---R----o---o------ to OPAmp
    R R
    GND GND to ground trough jumpers
    leave jumpers open for 0-5 range put one jumper for 0-10 two jumpers for
    0-15 range
    input impedance change on different range
    max134 from maxim show an interesting topology for input range selector
  4. If you're using an ADC you could consider use more resolution than you
    need and throw away an LSB or two for the lower voltage inputs.
    If you don't mind using jumper blocks, this is pretty easy/cheap:
    In Jumper position
    o 1: 0~15V
    | 2: 0~10V
    .-. 3: 0~5V (storage position for jumper block)
    20K0 | |
    1 | 2 3
    .--|--------. Out
    | o--o--o----------------o
    | o o o |
    10K0 '-''-'20K0
    GND
    You can buffer the input and/or output if you like.
    Best regards,
    Spehro Pefhany
  5. If you have a high input impedance and minimum settling time is
    important then you might be better off having a seperate resistor
    divider and buffer for each input and then have the mux on the low
    impedance output of the buffers.
    One fixed divider plus a programmable gain amp is probably the simplest
    solution though.
    Or simply a fixed 15V range and a higher res ADC as someone else
    mentioned.
    I think Maxim make ADCs with built-in selectable ranges like this.
    Dave :)
  6. jasen
    jasen Guest
    The third position isn't needed the jumper can be stored horizontaly
    Bye.
    Jasen
