Op amps problem Gain Calculation
Discussion in 'Beginner Electronics' started by N, Jul 4, 2005.
  1. N
    N Guest
    Note to view the schematic below, change your font to fixed Courier.
    I have a problem I am trying to work out on simple Op Amps gain,
    and I am having trouble trying to prove what the gain is.
    I know what the gain is supposed to be (see below), but
    I am stumped as to how to actually go about proving it. When
    I try to setup the Kirchoff node equations I get a really
    ugly polynomial.
    I can put the design into a spice deck and prove it, but I want to
    understand the design from an analytical point of view.
    Gain = 2*R2/R1 * (1 + R2/Rg)(V2-V1) (GAIN FOR THE OP AMP BELOW)
    Now looking at the above equation it is obvious if you
    eliminate resistor Rg, the equation becomes a simple
    differential amplifier gain, which I can easily solve and
    prove. However when you add the positive feedback from
    the output, you get a different Beta for the loop gain
    that is hard to figure out.
    Anybody want to take a stab at proving this?
    Nick ------------
    V1---------R1-----------------------R2-------R2---| |
    | ___ | |
    |--Vn| \ | |
    | \ Vout | Rg
    |--Vp| / |
    | | _ / -----------
    V2----------R1-----------------------R2-------R2---|GND
  2. Figaro
    Figaro Guest
    "N" <caprice24 at no spam yahoo dot com> wrote in message
    | Hi,
    | ugly polynomial.
    | Nick ------------
    | | ___ | |
    | |--Vn| \ | |
    | | \ Vout | Rg
    | |--Vp| / |
    | | | _ / -----------
    write the loop equations, apply the following op-amp tricks:
    1) currents into the inputs Vn and Vp are zero because op-amps have very
    input impedance
    2) Vn-Vp is zero because op-amps have very high gain
    and you will get your gain equation
