Op Amps - Low noise
Discussion in 'Electronic Design' started by MikeN, Jan 4, 2005.
  1. MikeN
    MikeN Guest
    I have a choice of two op-amps for an audio application.
    Which of the two, TL064 or TLC274 would generate the lowest internal
    noise in a 300 - 3000 Hz audio application.
    MikeN
  2. justin
    justin Guest
    In such a limited voice BW they will perform equally good or bad
    depending on the source, what is the impedance?
    FET opamps have better low input bias-current noise compared to bipolar
    input amplifiers. Bipolar opamps perform better if low voltage noise
    is an issue.
    J.
