op amp supply voltage
Discussion in 'General Electronics Discussion' started by idranoels, Apr 15, 2016.
  1. idranoels
    idranoels
    4
    Apr 8, 2016
    Hello
    I was looking at some op amp datasheet and i noticed that it's only indicated maximum supply voltage.
    Does it mean that inside this range I could use an arbitrary voltage level?
    E.g. could I use +/- 1.5 volt as a power supply for a tl071 or a 741 op amp? If I want to use it to build an audio preamp could I loose something?
    Thank you
  2. Kiwi
    Kiwi
    322
    74
    Jan 28, 2013
    From memory +5v to +15v is the preferred supply voltage for the 741.
  3. idranoels
    idranoels
    4
    Apr 8, 2016
    5532 is +/-5v?
  4. Herschel Peeler
    Herschel Peeler
    401
    65
    Feb 21, 2016
    Another thing to watch is the range of input and output voltages. The LM741 does not work well within a volt or two of the power rails. So trying to run it at +/- 1.5 V is impossible. Even from +/- 5 V you may only get a signal of +/- 3 V in or out. I don't know off hand what the TL071 is like, I suggest something in CMOS, rail-to-rail in and out (RRIO) is good, but you pay for it.
    (edited to add ...)
    Looking at the TL071 graphs it shows maximum output also being almost 2 V below the voltage rails, much like the LM741.
    AD820 or MCP6021 are rail-to-rail types.
    duke37 likes this.
