Kevin McMurtrie wrote...
... I can't find any specs on LH356 or LM356 but it's mentioned as
audio grade JFET input, the same class as the OPA134. You shouldn't
have any problems swapping the op-amp.
The part Tony is thinking of is the National Semi LF356 (note the F).
-p/n- f_T slew gain Iout noise Cin
LF356 5MHz 12V/us 106dB 15mA 12nV/Hz^1/2 3pF
LT1056 6.5MHz 16V/us 112dB 25mA 15nV/Hz^1/2 4pF
OPA134 8MHz 20V/us 120dB 35mA 8nV/Hz^1/2 5pF
The National Semi LF356 is a respected venerable opamp. Linear Tech's
replacement parts, the LT1056 and LT1057 (dual) are my favorite jelly-
bean JFET opamps. But, yes, the OPA134 looks a little better from
these specs. And they specify audio-range distortion - a nice touch.
But I'll stick with the LT1057's lower input-offset voltage. :>)
- Win
whill_at_picovolt-dot-com
