As duke37 says, an op-amp cannot produce an output voltage that is outside the voltages supplied to it. If you look up the data sheet on an op-amp, the output voltage swing will be specified.
For example, the Fairchild data sheet for the old 741 op-amp, at
http://media.digikey.com/pdf/Data Sheets/Fairchild PDFs/LM741.pdf
says that if the device is powered from +15V and -15V supplies and is operating into a load resistance of 10K or more, it can produce an output voltage swing of +/- 14V typically, and +/- 12V guaranteed. In other words, the output is only guaranteed to be able to swing to within 3V of the supply rails.
If you want to boost a supply voltage, you need a boost converter, which typically uses an inductor to store energy and release it at a higher voltage and lower current (like a transformer).
If you want to boost a variable signal, you need to use an amplifier that is supplied from voltage rails that are wider than the maximum required output swing by a small amount. The amount depends on how close to the supply rails the output can swing, which is determined by the design of the op-amp's output stage and is also affected by load current, or load resistance. Some op-amps have outputs that can swing very close to one or both supply rails, assuming the load current is low.
