I must be misinformed and/or confused...As audioguru says in #14 the signal is almost complerely cancelled at the - input. Therefore this can be considered as a virtual earth.
Current running into this position from whatever source has to be provided by the output of the amp. Thus the output current times the feedback resistor is the output voltage.
The input (channel 1/yellow) is a smooth sine wave, except for the slight distortion at the zero crossing.
Can you elaborate and explain?
