Op amp for RC servo audio-controlled
Discussion in 'Audio' started by seitam, Jul 28, 2013.
  1. seitam
    seitam
    4
    Jul 28, 2013
    Hello,
    I am developing a project that consists in controling a micro servo motor using the audio output of a smartphone (iphone/android, etc).
    I have used this scheme: (source: http://www.gluemotor.com/how-to-make)
    [​IMG]
    I also made the control signals (50hz, 1-2ms pulse) with matlab, and exported in .wav format.
    Here is a caption of the signal (audacity):
    [​IMG]
    Right now I am able to control up to 2 servo motors (one per audio channel) with my iphone, just reproducing the audio files.
    The main problem is when I try to do this with an android-based smartphone. All the android devices that I have used so far are not able to provide enough signal to run the servomotors.
    I read about how the control signal must be. I found that it is just a voltage signal that uses the values 0-5v. (0 for no signal and 5v for the peaks).
    I have not an oscilloscope, but I am pretty sure that the android devices that I have tested do not provide the voltage required of 5v.
    So to fix this problem I need to amplify the signal in order to get 5v on the peaks.
    I though that operational amplifiers may help me. So I get some 741 op-amp's and I mouted using the non-inverting scheme.
    [​IMG]
    The problem is that the output signal do not work with the servos. I have used a 1.5 battery to test the circuit (input), and the output was 2.75V using a 2.2k and 4,6k resistor (that is close to the ideal output of 3V).
    So the circuit seems to work well with a DC signal and having trouble with the "AC" one.
    Anybody can figure out where is the problem?
    I am using a 5v cellphone transformer to feed the op amp. I am using only 5v because this motors will be a part of project thats need to be powered up with 4 1.5 batteries.
    I read that the op amps like 741 are able to manage signals with no much delay and distortion below 1mhz, so the signal generated for the servos should not be a problem.
    I am completely lost, any help will be fantastic.
    Sorry for my bad english.
    PD: I have posted the same information on the forum allaboutcircuits, I post here the same for reaching most people possible.
  2. BobK
    7,682
    1,688
    A 741 requires dual supplies of at least +- 5V. Use a single supply op amp like the LM324.
  3. seitam
    seitam
    4
    Jul 28, 2013
    Thank you Bob,
    I will try with a low supply op amp so. I will post the results.
  4. BobK
    7,682
    1,688
    If you use a single supply amp, you will want to bias the + input at 1/2 the supply voltage and use a capacitor coupled (in and out) inverting amplifier configuration.
  5. seitam
    seitam
    4
    Jul 28, 2013
    I also forgot to mention that I removed the C1 and C2 capacitors, the servomotors just do not work using capacitors between the stereo plug and the input control signal. I send an email to the owner of this scheme (kazuhisa terasaki), because I didn't know why we need to put this capacitors. Nowadays I still thinking about his functionality. (I am so much limited in electronics knowledge).
    Why I need to bias the + input at 1/2 the supply voltage and use a capacitor coupled inverting the amplifier configuration?
    Maybe these are obvious questions but I am a newbye in electronics field, thank you for your comprension and time.
  6. seitam
    seitam
    4
    Jul 28, 2013
    Ok, problem fixed!
    The main problem was that the Vcc of 5v was not enough voltage to power up the 741.
    I have used a LM324N with a 100uF Capacitor. With the LM324N I am able to amplify up to 4 control signals.
    Thank you very much,
    Seitam.
  7. (*steve*)
    25,496
    2,837
    I'll remember that when I get a quadraphonic phone!
