D
I'd like to build a circuit to indicate that a car battery is charging (or not),
by the following means...
There is a small volt drop across the large conductor (about 8" long) that
connects the -ve battery to chassis, when current flows. This voltage is +/-
depending on direction of current flow in the cable. I've measured it with a dvm
and it goes from 2-3 to 15mV (lights off/on etc). The change of sign is clearly
seen when the engine starts and the battery begins charging.
Would it be a feasable thing to use this voltage as the differential input to
say a 741 op amp with the output driving a two colour LED? So I could see one
colour for charge and the other for discharge. If this -is- feasible I'd like to
drive the circuit from the battery itself (don't want a separate pp9 supply of
anything). As this would be the same single ended supply, but diff input, would
the idea still work?
Maybe there's an even easier way to do this - if so please enlighten!
Please no flames if this is stupid idea - it's been years since I built anything
electronic and I'd like to start a new project...
Thanks.
ps I don't want to use an ammeter!
Thanks.
