No, the 741 will not operate from a single supply with an input signal near ground.
Use a dual supply (e.g. +-5V). You can easily generate -5V from +5V using a
switched capacitor voltage inverter.
You may also wan t to use a modern OpAmp with better technical data, as the venerable 741 is rather outdated.
