One switch to rule them all
Discussion in 'General Electronics Discussion' started by bujaman, Aug 5, 2016.
  1. bujaman
    bujaman
    6
    Apr 26, 2016
    I am working on a home theater system and I have 2 motors that I would like to control with one switch. The projection screen has an AC motor, while the lift controlling the projector uses a DC motor. Is it possible to wire up both of these motors to be powered by one rocker switch? I have been sketching ideas on how to do it and keep hitting a wall. General thoughts of mine to this point is providing AC power to a box with the switch, DC power supply, and relay, but I am not sure if this is a) the correct direction to go, b) the simplest solution, and c) a wise thing to do. If there are any thoughts out there, I would love to hear them. Thanks.
  2. (*steve*)
    25,497
    2,839
    A switch with multiple poles can be used. This means the DC and AC can be kept separated.
  3. Sunnysky
    Sunnysky
    488
    126
    Jul 15, 2016
    DPST. Relay is the way to go. ratings depend on your specs.
    (*steve*) likes this.
  4. Alec_t
    Alec_t
    2,980
    806
    Jul 7, 2015
    Are both the screen AC motor and the supply for the DC motor powered from the mains?
  5. bujaman
    bujaman
    6
    Apr 26, 2016
    Yes, they are.
  6. (*steve*)
    25,497
    2,839
    Yeah, the above answers hint at the switch being used to control the DC and the DC controlling a relay to switch the AC...
    And
    Switching the AC (mains) which is also used to power your DC power supply.
    Both are good ways of keeping the (presumably) high voltage AC safely isolated from the (presumably) low voltage DC.
  7. bujaman
    bujaman
    6
    Apr 26, 2016
    Great, thanks for the advice on the double pole switches!
