D
David Collier
Sorry to get repetitive...
I asked a question above, but I'm not sure I got the specificity of
answer I was hoping for. Could I try again in more concrete terms please
I have a source of DC, 12 to 24V say. I have a switching PSU running off
the DC. The sink takes current in bursts at 2us intervals. The 500KHz is
approximate, but reasonably stable and accurate.
see http://www.Micrel.com/_PDF/mic2198.pdf
I'd like to be able to draw 15W in bursts, so assume average input
current of 1 to 2A on full load.
That causes noise on the wire going back to the supply. That stops me
getting CE approval for the box ;-(
I need to kill the noise.
All the PSU chips which run at fixed frequencies say "this makes the
noise easier to filter" - Hmmm. how exactly?
I appreciate that there will be noise at 2us and harmonics at higher
frequencies. We have already fitted a proprietary input filter, which
sadly seems to provide little attenuation as far down as 500KHz.
BNX002-01 http://www.Farnell.com/datasheets/6821.pdf page 14
It doesn't appear that [ after the filter get to them ] the harmonics
are large enough to cause a problem.
Yes I know, shoot the designer who matched that filter with that
switcher. The bullet is on it's way.
So I have just the one problem - noise at 500KHz.
I COULD treat it by just building/fitting a 'bigger/better' filter with
a cut-off frequency well below 500KHz. But I have a PCB artwork already,
and PCBS built, and that would require making new PCBs. I'd like a
retrofit mod if I can work one out.
Now, back when I did exams, I seem to remember circuits which would
exhibit a high impedance at a single frequency. usually consisting of a
cap and inductor.
something like
http://www.allaboutcircuits.com/vol_2/chpt_8/6.html
Could I "fix" the problem by fitting such a cct? Would the components
required fit inside a small building if I did? Should I stop trying to
be clever?
I can buy a 2A-rated inductor at about 33uH
http://www.Coilcraft.com/pdfs/dc1012.pdf
to get the resonant frequency to be 500KHz I'd need a capacitor of
C= 1/( 4 * PI^2 * L * F^2 ) ???
3nF???
Sounds a bit small... maybe I could use a smaller inductor and a larger
cap?
Maybe I should just fit a 1R/inductor in series and change the input cap
to 220uF low ESR instead of 22uF.
Is there a better way, maybe by building a suitable notch-filter circuit
and fitting it into the DC supply lead outside the box for now?
All help appreciated.
David
cap and inductor.
something like
be clever?
3nF???
cap?
David
