One Hour Appliance Timer--Where Finde?
Discussion in 'Electronic Basics' started by W. Watson, Feb 6, 2004.
  1. W. Watson
    W. Watson Guest
    Where can I get an appliance timer that I can just set to some time between 0 minutes
    and 60 minutes to turn on a 1500 watt heater, and then turn it off? I'd like not to
    have to wire it into the AC circuit. It should be like a typical 24 hour appliance timer.
    Wayne T. Watson (121.015 Deg. W, 39.262 Deg. N, 2,701 feet, Nevada City, CA)
    -- GMT-8 hr std. time, RJ Rcvr 39° 8' 0" N, 121° 1' 0" W
    "Birds take off at sunrise. On the opposite side of the world, they are
    landing at sunset. This causes the earth to spin on its axis." -- Unknown
    Web Page: <home.earthlink.net/~mtnviews>
    sierra_mtnview -at- earthlink -dot- net
    Imaginarium Museum: <home.earthlink.net/~mtnviews/imaginarium.html>
  2. JeffM
    JeffM Guest
    an appliance timer...time between 0 minutes and 60 minutes
    http://www.grainger.com/
    You will likely also have to get
    a junction box, outlet, and line cord / plug
    and wire it up as a stand-alone unit.
    BTW, make sure that this 1500W load
    is the only thing on the circuit (breaker).
  3. W. Watson
    W. Watson Guest
    Sounds like a good solution. Why the only thing? I would think most circuits could
    handle a few thousand watts. Is it something about the timer box itself?
  4. JeffM
    JeffM Guest
    Making certain assumptions and erring on the safe side.
    I'm thinking 15A residential breakers and inrush current.
    1500W / 120V = 12.5A continuous ( + cold element surge)
