marktisaac
- Mar 23, 2014
- 5
- Joined
- Mar 23, 2014
- Messages
- 5
Hey everyone! So I've got this problem, and figured I'd use the guidelines posted in the sticky thread. I have tried cleaning the springs, and it didn't really work. So I was hoping someone could tell me 1)how to repair this issue 2)where to purchase spare parts for this job.
0) What is the device. Obvious maybe, but people have forgotten to mention. Is it a TV, an external hard drive, an alarm system, or what? Make and model is appropriate where known. (Also how old is it. If it's still under warranty this may suggest an alternative response).
The item here is an OM-84 Suzuki Omnichord It is about 25-30 years old and is no longer under warranty.
1) What is the fault -- "Not working" is not helpful. Saying that the power light goes on, then immediately goes off again when you try to tun it on is VERY helpful.
Everything about the item works. The only trouble I'm having is with the battery connections. As you can see from the photos they are terribly corroded. The item works with an AC adapter, but I'd like to make the system portable again and fix the battery connections.
2) History of the fault. Did this happen suddenly? Has it been happening for a while, but now happens all the time? Does it begin to work after several tries?
I bought this item used, and at a great price so I didn't mind that the battery connections were so terrible. But, this has been happening since I received the item (and probably long before that.)
3) Actions unspecified in the manual. Has it been dropped, dunked, spilt over, left in the sun, left without ventilation, had the wrong plugpack fitted, etc.
While I have had the item, no harm has come to it, but I'm assuming the previous owner had left batteries in the Omnichord and let them corrode.
4) Does anything look or smell burnt? Look on both sides of printed circuit boards and look at the board too.
nothing smells burnt.
5) Do any components look "wrong". An example might be something having a different or uneven colour compared to similar components, or components leaning over when others are all upright, or, well, anything unusual.
Springs for battery connection.
6) PHOTOS -- Please give us some good photos of any areas obviously affected.
https://flic.kr/p/mn6P47
https://flic.kr/p/mn4VhK
https://flic.kr/p/mn4Wp4
https://flic.kr/p/mn6SkY
https://flic.kr/p/mn4Ysc
