A
ASAAR
Yes. Mild dyslexia. Bad place for it to happen, though. :-]
You probably need more sleep.
Yes, of the eternal kind.
BC said:It is called a color wheel, not a "triangle"--at least it was when I got
my degree in color. White light is a full spectrum.
Pantone Calibration instrument.
Except, LCD displays are not really subtractive color systems. They
have filters to provide primaries, which are then ADDED by the limited
resolution of the human eye (just like the striped color CRTs).
If they were full subtractive color systems with three layers, they
could generate any color at any physical spot on the screen. This could
increase the color resolution.
However, as with the CRT, it doesn't matter, because the color resolution
of the human eye is substantially less than the luminance resolution, so the
effort for increasing color resolution would be essentially wasted.
How about to have a display for portable devices (like cellphones)
that has lower power consumption than backlit displays. Such a device
would not need the high voltage source for the backlight, so would
save some manufacturing cost.
Roy L. Fuchs said:Try again. Illuminated pixels will always beat backlit filtered
subtractive color mixing schemas.
Why do you think there is even a move toward OLED to begin with,
boys?
Aw, don't try to confuse the issue with facts.
It is called a color wheel, not a "triangle"--at least it was when I got my
People that are as defensive as you usually turn out to be dumbass morons.
You use insults and anger to hide your ignorance.
For my work I know this: CRT's aren't as sharp or detailed as LCD.
You're a joke.As far as practical application--that I use--it is better. I compare my
Viewsonic 19" to my Trinitron CRT. My print match is better and both were
calibrated. The LCD is also sharper.
Why? Ancient history that's why.
Putting the same image on my trinitron and on the LCD, I will see more
detail in the LCD image. Practical facts.
Oh and you are right about not knowing what a motion artifact is--on my LCD
I NEVER see them. I watch sports--never see them--action movies--never see
them. Depending on the broadcast I do see when crews aren't using HD
cameras or the really good HD cameras.
Facts?
Three backlit "filtered" light sources ARE subtractive method. The
three together form clear or white, not black.
Opaques are additive color mixing. The three primaries added make
black.
Well I was actually specifically referring to large form factors.
Eventually, it will be the display of choice. The 19 Million pixel
IBM already is in the movie industry.
Interesting claim. A bit of google searching found no references to
this 19 million pixel IBM display. Can you provide some pointers or
other information that will allow one to find any more information on
it?
Alan
Alan Larson said:Additive color adds the primaries {red, green, blue} to make white.
Indeed, additive color mixing is used with light sources, you add light of
different colors of light to the dark.
Subtractive color uses {cyan, magenta, yellow} - when all are used
to generate black.
And sbutractive colors are used with ink/paint on white surface, hence you
subtract colors from the white surface.
Meindert
it?
Alan
They made it like two or more years ago. It is not a production
item.
It does 24 Hz at its max res.
What is a backlight?Alan Larson said:Indeed, additive color mixing is used with light sources, you add light of
Meindert
On a crt, there is no e-beam on a black image. How is black created
on an LCD?
When the light source is white (as with a backlit LCD) then the filters inYou must be trolling.
to generate black.
Look it up.
Alan
Neil Ellwood said:When the light source is white (as with a backlit LCD) then the filters in
front subtract the light and therefore the three primary filters will make
black. Do not confuse this with colour printing.
Roy L. Fuchs said:On a crt, there is no e-beam on a black image. How is black created
on an LCD?
