Hey folks, I've been a bit into electronics lately (built a few guitar effect pedals) but not much other than that. Recently I've purchased a turntable which I connected to an old amplifier (I think it's from the 90's- possibly 80's). The turntable is connected to the amp via phono connections. When I connected it for the first time it didn't play a sound at all. After playing a bit with the connectors (spinning them around, in and out, etc.) the amp started working, however one channel (right one) didn't play at all. I opened the amp and when I touched the phono preamp curcuit (the back side of the transistors and capacitors) with my finger, the speakers produced a low frequency 'boom' sound and then the music started playing for a while and stopped. This repeated itself every time I touched the circuit. shaking the amp or hitting it (not to harshly of course) also makes it work sporadically.
I finally unscrewed the entire thing and sprayed everything with a tuner cleaner, and polished off the corrosion from the connectors. After that the amp started playing well (for a couple days) but now it spontaneously stops producing sound from the right speaker (or both of them). When it does work, the right channel is still much weaker then the left one so I have to rotate the balance pot almost all the way to the right.
I guess that this is mostly a dry joints problem but my knowledge in electronics is very poor. Will supply pictures if needed.
Thanks!
Thanks!
