P
Peter Mance
I've got an old Sony power amp, TAN-7B, that i've had for years.
One channel has gone noisy.
I'm trying to fix it but having a bit of trouble working out which component
is causing the problem.
Its all discrete, FET's, transistors, diodes, capacitors... All the good old
fashioned stuff.
Disconnecting the driver stages from the power stages has eliminated the
power stages.
I've swapped the few capacitors with the corresponding ones from the other
(non-noisy) channel, so its not a cap.
Which components are most likely to go noisy?
Any suggestions for best approach to track such a thing would be
appreciated.
NB. The power rails are clean. so there arent that many options.
Thanks in advance.
fashioned stuff.
power stages.
appreciated.
Thanks in advance.
