Old Motorola TV model ???
Discussion in 'Electronic Repair' started by [email protected], Mar 25, 2007.
  1. Guest
    I am in the process of resotring several old tv's given to me deveral
    years ago. I am now trying to figure out a 10" Motorola tv without
    any model number. The back of the set is missing. Inside the wooden
    cabinet, the sticker on the side is missing except for a tiny scrap
    with no writing. Only info is stampings on the metal chassis.
    222453, TS53, 3M50. The set appears to be about 1948 - 50, but
    that is not much help. The H + V + Brightness controls are all on the
    back chassis. The cabinet has been painted so no other info there.
    Any help in identifying greatly appreciated so I can try to find a
    schematic.
    H. R.(Bob) Hofmann
  2. Fred Wesner
    Fred Wesner Guest
    Bob is it this one?
    http://www.geocities.com/k8zhd/tvs/motorolaTV.htm
    Fred
  3. DaveM
    DaveM Guest
    Chassis number TD53 is in the Sams database as a Quasar model, in Photofact
    folder 115-7. You should be able to buy a copy of that folder from Sams.
    http://www.samswebsite.com/photofacts.html
    You might be able to find somebody who has that folder and would be willing to
    copy it for you.
    Cheers!!
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Life is like a roll of toilet paper; the closer to the end, the faster it goes.
  4. hr(bob)
    hr(bob) Guest
    It sure looks the same. My set does have a 12" tube, contrary to what
    I posted earlier - 10". It is in the garage and I didn't measure
    carefully enough in the half-darkness.
    I just checked and I have Photofact 115, pulled out the Motorola
    folder - BINGO!!! ts53 is shown on the photofact.
    I am assuming the voltage doubler in the power supply uses selenium
    rectifiers, I haven't turned the set on yet or pulled the chassis, so
    I don't know if I will receive the selenium smell or the electrolytic
    explosion noise first. Maybe I'll be lucky and neither. I will bring
    the set up on a variac just to play it safe.
    Thanks VERY much, hope I can help someone else someday.
    BTW, I do have a lot of old photofact folders, if you need something,
    let me look and see what I have. I can scan and send.
    Bob Hofmann
  5. hr(bob)
    hr(bob) Guest
    I initially searched Sams for the TS53 and didn't find it, so came to
    this group next. Just now I checked and I have photofact folder 115
    and the schematic is there. Now I have to decide if I want to do the
    cabinet as well as the electronics. Will leave the cabinet till I see
    how the set works after restoring, esp the pix tube.
    I have a lot of old photofact folders, let me know if you need
    anything copied.
    Bob Hofmann
  6. clifto
    clifto Guest
    If the set appears to be about 1948, it's not a Quasar.
    TS53 looked like Moto's type of chassis number.
  7. Fred Wesner
    Fred Wesner Guest
    Great, see there was a reason that you kept that old Photofact many
    years ago!
    You will probably hear a little pop and then nothing. Many of those hot
    chassis sets used a fusible resistor in front of the seleniums. It
    will, I guarantee, pop if it hasn't already done so.
    You are very welcome and thanks for the offer, will keep it in mind. Do
    post as you work on this set, some of us will find it very interesting.
    Fred Wesner
    San Jose, CA
  8. DaveM
    DaveM Guest
    Yeah, I made a typo on the chassis number.. . meant to say the TS53.
    I saw the manufacturer listed as Quasar rather than Motorola in the Sams index.
    I didn't think the Quasar line didn't appear until the solid state sets were
    marketed. Probably some techie at Sams just made some wrong selections when
    creating the index.
    If the set has been in the attic for many years, I'd recommend that you replace
    all the electrolytic capacitors first.. before turning the set on. Especially
    the caps on the B+ line.
    If you have a leaky B+ filter cap, it might well take the rectifier and power
    transformer out before it gets warmed up. Those power transformers are not easy
    to find, and will be quite expensive if you can find one.
    Dave M
    address)
  9. start here:
    http://www.tvhistory.tv/1946-49-MOTOROLA.htm
    Joe Leikhim K4SAT
    "The RFI-EMI-GUY"©
    "Treason doth never prosper: what's the reason?
    For if it prosper, none dare call it treason."
    "Follow The Money" ;-P
  10. If you use the electronic Sams Photofact index, keep in mind that
    they list all of the early Motorola under "QUASAR".
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  11. Tell that to SAMS Publishing. They list all early Motorola models as
    "QUASAR". I emailed them about it about a year ago, and never got a
    reply.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  12. clifto
    clifto Guest
    Leave it to Sams. I never heard the word "Quasar" in relation to a
    television before what, early seventies? just before Motorola mercifully
    went out of the television business.
  13. I think that the company that created and maintains the electronic
    index for Sams Publishing decided that it was all "Quasar" because that
    was the name Motorola sold (along with their consumer electronics
    division) to Matsushita (Panasonic), in spite of the fact that there was
    more models branded Motorola than ever had the Quasar name.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  14. jim menning
    jim menning Guest
    Sam's apparently made that classification change long ago, well before the online
    electronic index.
    The 1992 (paper) index here in my hands indicates that Motorola Auto & CB Radio
    products will be found under "Motorola", and that Motorola Home Radio, TV, and Tape
    products will be found under "Quasar".
  15. My last printed index still listed them as Motorola, and I haven't
    seen it in years.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  16. jim menning
    jim menning Guest
    I actually keep several editions handy. In the early years of Sam's indexes, many of
    the radios and TVs were listed both by model and chassis number. Locating schematics
    by chassis numbers has come in handy often over the years.
  17. Mine were in storage when I got sick, and lost my job, then the
    warehouse.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
