Old magazine series 99 IC projects
Discussion in 'General Electronics Discussion' started by bertus, Feb 9, 2021.
  1. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    In the 1979 one, I see a gizmo for a bar graph, and someone needed one for his water tank not long ago. =)
    It works with a strange technique of dropping voltage through diodes, but I dont see how it works entirely. Its actually an ADC! but you need one bar per bit, not one bit per power of 2 of the result, goes to show if all you need is 8 bit resolution ADCs sample as fast as you want, as long as you put the full 256 lines down.
  2. bertus
    bertus Moderator
    1,893
    711
    Nov 8, 2019
    Hello,
    Did you read the text of the led bar graph?
    When turning up the voltage, led 6 will be on first, then about 0.7 volts higher led 5 will turn on etc.
    Bertus
    ratstar likes this.
  3. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    I see, I was thinking it was a current dependant input! i see now. cool.
    You can exchange the diodes for voltage dividers, if your short on semiconductors. :)
    So does that mean you just put a current divider instead of a voltage divider you get the current version!?
  4. Nanren888
    Nanren888
    479
    139
    Nov 8, 2015
    Diodes used to set voltage thresholds is not an uncommon technique.
    Here it would give a soft turn on, for each LED, I guess.
    256?, OK :) with 256 LEDs, maybe 32,768 diodes, about 150 volts and 256 resistors, ratings for that voltage & quiite a lot of current.
  5. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    Pure Parallel does increase power requirements - but it would potentially give you sub pico-second sampling, if you handled all the other problems, which I'm not aware of yet.
  6. Harald Kapp
    11,522
    2,654
    ratstar likes this.
  7. TCSC47
    TCSC47
    105
    30
    Mar 7, 2016
    Love these 99 cct books and others like them. When I was an apprentice and we were being taught valves (It was the 60s!) I got hold of a Practical Wireless, cct pocket booklet. I spent a lot of my time knocking up the transistor ccts and learning from them. Didn't get very good marks from my supervisors, but I found I knew a lot more about transistors than any of my apprentice colleagues.
  8. ratstar
    ratstar
    486
    20
    Aug 20, 2018
    Maybe they were jealous.
    TCSC47 likes this.
  9. bertus
    bertus Moderator
    1,893
    711
    Nov 8, 2019
    TCSC47 likes this.
  10. TCSC47
    TCSC47
    105
    30
    Mar 7, 2016
    No, I just didn't realise that I was supposed to do as I was asked to! You get wallys like me everywhere! Lol! Took me a while to figure this out. Mind you it enabled me to walk straight into a job after my apprenticeship.
  11. TCSC47
    TCSC47
    105
    30
    Mar 7, 2016
