Old Capacitor Codes?
Discussion in 'Electronic Basics' started by Grant Stockly, Apr 26, 2007.
  1. I have second hand word that a specific capacitor is a Z5U 1000M 1KV.
    This doesn't follow the standard 3 digit capacitor code. Is it
    possible back in the 70s that 100pf could be written as 1000M instead
    of 101M?
    Grant
  2. Eeyore
    Eeyore Guest
    Z5U is the dielectric.
    M is the tolerance code - 20% IIRC.
    It looks like 1000 pF to me.
    Graham
  3. Tom Biasi
    Tom Biasi Guest
    You have a 1000pF 1000Volt cap.
    "In the 70s" 1000pF would have been 1000MMF.
    M meaning micro (10^-6)
    I bet some guys here called them Mickey Mikes.
    Tom
  4. "Picklefarts" was used a lot more than "Mickey Mikes".
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  5. Radiosrfun
    Radiosrfun Guest
    Been a long time since having heard the term - Mickey Mikes, but can't
    recall ever hearing "Picklefarts". I "may" have - just can't recall it at
    moment.
  6. It might have been a regional thing. It was a common term around the
    shops I worked at as a kid.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  7. Actually, by the 70's it was pretty much over.
    IN the early sixties, about 1963, some standards organization cleared
    out some of the rot, so there was a more consistent useage. It
    was the same thing that brought in the term "Hertz" rather than
    the previous "cycles per second".
    And that's when pF came along, to replace the somewhat odd "mmf" or
    "uuF".
    By the seventies, the only reason you'd see "mmF" is because parts
    still in use were marked that way, and the relative oldtimers hadn't
    switched over. It was no longer showing up in the magazines.
    Michael
  8. John Fields
    John Fields Guest
  9. But my point was that "uuF"/"mmF" was no longer used by the seventies.
    Michael
  10. John Fields
    John Fields Guest
  11. Eeyore
    Eeyore Guest
    Or 1000 uuF
    But only in the USA.
    Graham
  12. Eeyore
    Eeyore Guest
    Over here we call them puffs or puff.
    Graham
  13. Eeyore
    Eeyore Guest
    Only true of the USA.
    I was using nF well before that time.
    Graham
  14. Eeyore
    Eeyore Guest
    But you Americans drag your feet over everything.
    I was using nF in the late 60s. My Philips "Transistor Audio and Radio Circuits"
    handbook has nF and it was printed in 1969.
    Graham
  15. Radiosrfun
    Radiosrfun Guest
    Around "here" - I heard them referred to that as well.
  16. I believe you, but I've never met a puff in the USA.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  17. nF was in use in the early '60s, but it went away.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  18. Lionel
    Lionel Guest
    Over here, we used to call them "puffs".
    As in: "Anyone got a 100 puff cap in their kit?"
  19. Lionel
    Lionel Guest
    Ditto. "nF" was in common use in Oz at least as early as the mid 70s.
  20. John Fields
    John Fields Guest
    So were we.
    The point I was making, which you seemed to have missed, is that
    Michael Black's comment that: "Actually, by the 70's it was pretty
    much over." was untrue since the old notations lingered for a long
    time.
