Old Betamax channel indicator lights, not LED.
Discussion in 'LEDs and Optoelectronics' started by Sparklezap, Mar 5, 2016.
  1. Sparklezap
    Sparklezap
    Mar 5, 2016
    Hi. I've been trying to find these bulbs, no find. They look just like a NE-2 except they are white. They light up a light green color. I use an 82k-100k resister on 120 volts. I've had them last for at least 20 years! Any input?
  2. Minder
    Minder
    3,119
    673
    Apr 24, 2015
    A mixture of Neon and Krypton will glow green on a Neon lamp, if they are AC fed then that is what these are, I suspect you may have a problem getting BetaMax parts!!
    M.
  3. 73's de Edd
    73's de Edd
    3,138
    1,320
    Aug 21, 2015
    Sir Sparklezap . . . . .
    Get ready to have cornered the US market on them.
    As this should be a lifetime supply for you . . . . . ..
    http://www.ebay.com/itm/20pcs-Green-4mm-Neon-Light-Bulb-Indicator-4X10mm-Lampada-Lamp/252285177923?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=4754e5f396a44ce3940491142130feaf&pid=100005&rk=1&rkt=6&sd=252285177925
    In addition to their gas fill mix, they are also utilizing a fluorescent coating for even greater color enhancement.
    There is further confirmation, by these additional color offerings . . . . . . with the bare glass units being specified as "RED" . . . . . . but, assuredly being ORANGE.
    http://www.ebay.com/itm/20pcs-Each-RED-Green-Blue-Mix-Bulb-Indicator-4X10mm-Lamp-Neon-Light-Lampada-New/252285177924?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20131003132420&meid=32e920aced284552a49acec0ce202c3b&pid=100005&rk=4&rkt=6&sd=252285177923
    73's de Edd
  4. Sparklezap
    Sparklezap
    Mar 5, 2016
    Thank you so much to Id these. NE-2G. Many are discontinued as I look for them. But just got a post below for a good deal. I learned a lot from your input. Thanks.
