Old B/W pc monitor conversion possible?
Discussion in 'Electronic Repair' started by Bart Bervoets, Jul 26, 2004.
  1. Is there a way to feed composite video in an old B/W pc monitor?
    This for use on a security system (the person asking has 4 of those
    very neat small monitors used on checkout systems.)
    Bart Bervoets
  2. Hi!
    There exist ready made boxes to do this...one that I've had experience with
    is the so-called PS/2 TV, made by Rexon-Techmar under that name and also
    their own brand, which I don't recall. If you can find one used it might be
    a nice solution to the problem at a reasonable cost, but it requires at
    least the +5V from the keyboard plug to get it to turn on.
    I used mine with an IBM 8504 VGA monochrome display and that monitor really
    made a nice B&W TV set.
    There are other more modern solutions but they are not cheap.
    William
  3. Guest
    Probably not, most of the early PC monochrome monitors used a digital
    input, not analogue video.
  4. James Sweet
    James Sweet Guest
    Chances are these are mono VGA monitors, it can be done, but it's certainly
    cheaper to find some mono composite monitors.
