Oil-Filled Pressurized Relay Sticks ON and Burns Up (Why?)
Discussion in 'General Electronics' started by Bookmarkw, Aug 14, 2004.
  1. Bookmarkw
    Bookmarkw Guest
    I've got a mechanical (i.e., not solid state) relay I'm using in pressurized
    oil. Some boards work fine. Some, though, stick ON under pressure. Some burn
    up. Holes are drilled in the package to allow oil in (to prevent the package
    from collapsing.) The voltage connected to the relay is 240VAC.
    Can anyone suggest a cause/solution?
    Thanks!
  2. Robert Baer
    Robert Baer Guest
    You did not indicate whether that 240VAC is on the coil or the
    contacts or both.
    In any event, check that the peak load current handled by the contacts
    is well under the rating.
    Also, check if the load is inductive and verify the proper snubber is
    across the contacts.
    Next, add a thin piece of paper between the pole and the armature;
    this insures a magnetic gap when closed, and increases the drop-out
    voltage and prevents magnetic "sticking", especially with DC on the coil
    (Note: the added gap has zero effect on pull-in voltage).
