Ian Wallis
- Nov 13, 2017
- 23
- Joined
- Nov 13, 2017
- Messages
- 23
Hi, I want the lighting, off grid in my house, max 7 bulbs 12 volt 9watt each, using two new deep cycle 75amp batteries. Do you think 150 amp will be enough for 4 to 7 bulbs for six or seven hours?
The idea is to take the lighting cables out of the consumer unit, and run them to the garage where the batteries are. Will a 100 watt solar panel be enough to charge them at rate of 5 amps? Or should I go 200 watt and 10 amps? Obviously I'd like more batteries but they are so expensive.
Any input welcome.
Any input welcome.
