"Tak"wrote
Need a graph of impedance (both R and X) relative to off-center
distance on a half wave dipole.
Anybody have ot handy? Searched on web and books but could not find.
You're looking in the wrong places. Even Terman and probably Kraus are
silent.
The input impedance of an off-centre fed 1/2-wave dipole is always purely
resistive (because the antenna is resonant), with approximately -
R = 73 divided by Square( Cosine( Theta ) ) ohms.
Where Theta is the angle 180 times D divided by L degrees,
D is the distance from centre and L is the overall length in any units you
like.
But, be warned, if not at the centre, as soon as you connect your feedline
you will make a mess of it depending on height and on length and impedance
of the line. The feedline becomes a part of a far more complicated antenna.
On the other hand, the approximation is good enough for other calculations
provided the connection is, say, not more than 1/2 of the way to the end of
the wire.
You will have to plot your own graph. ;o)
