OEM
Discussion in 'General Electronics Discussion' started by jhayar25, May 22, 2012.
  1. jhayar25
    jhayar25
    47
    Mar 28, 2012
    pls help any one can give an idea or method on how to locate the oem or factory - unlock signal of cars pls give me even a diagram or any site,video....thank im installing a car alarm upgrade...
  2. Wabajig
    Wabajig
    75
    Apr 14, 2012
    Well I was acquainted with car alarms 10 years or so ago. So if they are using the same technology, one type is the key has a pill in it which looks like a black dot on the key. It really is a resistor, so you can measure the value and bypass the pill. The other was a transmitting type in a the large head of the key, in which you could use what we called a bypass kit, so you can install your own alarm system. Otherwise, there are nice instructional videos on youtube for your type of car and alarm. Good luck and hope this helps.
Similar Threads
Loading...
