oddball cable needed
Discussion in 'Electronic Repair' started by Ray L. Volts, Jul 4, 2006.
  1. Ray L. Volts
    Ray L. Volts Guest
    Googling yielded nothing close. Wouldn't ya know, there's no marking on the
    cable. If it was a custom, limited production run, so be it, but perhaps
    it's available stock somewhere.
    The cable is 3-conductor (each is 22AWG with 26 strands). Strain relief
    consists of 3 braided nylon cords (0.5mm diameter each) with each cord
    sandwiched between 2 conductors. The conductor/cord bundle has
    approximately 25mm (1-inch) turns. For additional strain relief, all the
    above is surrounded by a flat, unbraided nylon fiber wrap with 14mm
    (half-inch) turns. There is no trace of lubricant. OD of cable is 4mm.
  2. Can you post a picture on the web?
  3. Ray L. Volts
    Ray L. Volts Guest
    I know it sometimes helps to have a visual, but I've no working digicam atm.
