Odd Question About Circuit Board
Discussion in 'Electronic Basics' started by Kevin der Kinderen, May 22, 2005.
  1. I recently bought some parts kits from a company called NIGHTFIRE. I don't
    have much experience playing around with circuits but I thought this might
    be a nice introduction and a good way to build up my junk box.
    The kits come with a blank PCB with 162 plated through holes. All the holes
    are independent - I mean they don't connect to anything else. How do
    interconnect components on this board? Is it made for wire wrapping maybe?
    Or do I bridge adjacent holes with solder? I can't figure out how to make
    use of it. I remember the old perf boards but I can't figure out what the
    use of the plated through holes are?
    Here is a link to the particular board...
    http://www.vakits.com/product_info.php?cPath=98&products_id=157
    Thank you,
    Kevin
  2. JazzMan
    JazzMan Guest
    Generally, this type of board needs wire wrapping.
    JazzMan
    Please reply to jsavage"at"airmail.net.
    Curse those darned bulk e-mailers!
    "Rats and roaches live by competition under the laws of
    supply and demand. It is the privilege of human beings to
    live under the laws of justice and mercy." - Wendell Berry
  3. You can stuff 2, 3 or perhaps more component leads in each hole on one side
    which will be your component side and install jumpers on the other side or
    both sides, its your choice. Most of us install the parts on one side and
    most of the wires on the other side. You'll end up with a prototype for a
    printed circuit board if you do a good job. Also good for one of a kind,
    quick and not so dirty.
  4. Thanks for the quick responses!
    Kevin
    KJ4QF
  5. Plated through holes are fine for mounting parts including ICs and IC
    sockets. You can often play around with the parts arrangement before
    soldering to get common nodes in adjacent holes and groups of commoned
    parts in straight lines.
    Then you use a fine wire to connect the soldered in parts. It is
    tempting to bend the part leads over to make these connections, but it
    makes any changes really destructive.
    My favorite wire for the interconnections is the silver plated, Kynar
    insulated 30 ga. wire wrap wire (sold for a high price at Radio shack
    in 4 different colors). It strips very easily and solders well. For
    insulated runs, you can solder one stripped end, measure the length
    needed to reach the next node, clip and strip 1/16th inch of that end
    and tack it down, for a neat board. Some prefer right angle routing,
    but I like straight runs, since I usually can lay out the components
    so that few are needed.
    Get a pair of fine pointed tweezers to hold small bits during soldering.
