L
Lance Morgan
CJT said:Lance Morgan wrote:
It sounds like it's working fine. What you're calling the vertical
portion of the trace happens much faster in time than the horizontal.
Thus, it's not nearly as bright. If you cranked the brightness up
you could perhaps see it, but there's no need -- you know it's there.
You could also speed up the timebase and try to see more of the
risetime of the square wave.
Thanks. I'm carefully fiddling w/the settings, including CRT, but it
makes it difficult to see if square wf is really square - hard to ck for
rounded corners/distortion. I was hoping to see a nearly frozen/slow
"showcase" pattern
I'll try to make better use of the graticule and keep acclimatizing
