nylon/plastic nut needed
R
RB
Looking for a 1" x 14 fine thread nylon/plastic nut to use on the layover
marine antenna mount post.
I've found a bunch of online sources for nylon and plastic nuts, but they
don't quite make it to 1"x 14. Close, but not right on.
If anyone knows where I can buy two or three of these, I'd appreciate
hearing from you on it.
D
Doug Whitman
layover
Try McMaster Carr: http://mcmaster.com If it is hardware and it i
for sale, they should have it.
Dou
S
Sunset Sam
McMaster Carr is a good suggestion. If you run into a dead end there
I'd suggest contacting a plastic distributor. Not a molder, but
somewhere that carries rod & sheet stock. They can fabricate a nut for
you pretty inexpensively. Either cut out of nylon plate stock, or
sliced off nylon rod stock. The drilling and threading wouldn't be a
big deal if a person had the right size tap.
A
Alec
This thread is used by the major antennae manufacturers.
Try them or antennae suppliers.
Alec
