nylon hardware
Discussion in 'Electronic Repair' started by [email protected], Jun 30, 2005.
  1. Guest
    This has to do more with fabbing than repair.
    I want to find some #6 nylon machine screws and nuts. This would make
    my life much easier when screwing down TO-220 transistors. I can't use
    clips on the stuff I make because the transistors attach to the
    enclosure, not individual heatsinks. I have my own insulating sheet
    material and I don't want to buy a mounting hardware kit for each
    transistor, it would cost more than the transistors. I need
    nonconductive fasteners.
  2. Steve Noll
    Steve Noll Guest
    McMaster-Carr
    http://www.mcmaster.com/
    Steve J. Noll | Ventura California
    | The Used Equipment Dealer Directory:
    | http://www.big-list.com
    | The Peltier Device Information Site:
    | http://www.peltier-info.com
  3. lakewood
    lakewood Guest
  4. X-Trace: posting.google.com
    Far too often you find new text posted through News.Google with *no*
    accompanying quoted material. But this is the first I've seen via that
    route with only quoted material -- and *no* new text. :)
  5. Guest
    I think Digi-Key and Mouser both carry these.
    Matt Roberds
  6. CharlieMax
    CharlieMax Guest
    You can find Nylon hardware at : www.mouser.com
    More specifically : www.mouser.com/eagleplasticdevice
  7. Guest
    You're right! Digi-Key has nylon screws... about $10 per 100 screws in
    the size I seek, and I was getting ready to order some stuff from them
    anyway.
    McMaster Carr charges several dollars PER SCREW (PTFE -- no mention of
    nylon).
  8. Steve Noll
    Steve Noll Guest
    Look harder!
    McMaster-Carr is about half that.
    Example:
    p/n 94690A110 4-40 x 1/2" Nylon binding head $4.80/100
    p/n 94690A146 6-32 x 3/8" Nylon binding head $4.93/100
    p/n 94812A112 4-40 Nylon nuts $5.13/100
    Search for 'plastic screws' and 'nylon nuts'
    What more do you want?
  9. none
    none Guest
