When calibrating op amps outputs, you have to use a resistor decade box to null out the output of the op amp to zero volts
Each op amp is output .100 to .900 millivolts
This is when there is no input signal
When nulling the output of op amps or a circuit stage so it's zero volts potential , is this biasing?
Or what is it called or doing to the circuit when you null it out like this?
