Nrf24l01 pa+lna current consumption
Discussion in 'Microcontrollers, Programming and IoT' started by Ankish, Aug 19, 2017.
  1. Ankish
    Ankish
    Aug 4, 2017
    I am using nrf24l01 for data transmission bit not getting the desired range even after setting the rate to 250kbps and power setting to 0db.when i break vcc and introduced a ameter it only showing 3ma of current which is not valid as per its datasheet don't know what is the problem.
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Sure about the current consumption? The data sheet shows Ivdd(avg) as 0.12mA for the -6dB output level and in burst mode (not knowing what mode you're using of course...).
    What is your 'desired range'? and what is the terrain between tx and rx?
