nRF24L01 2.4GHz tranceiver - ATMega328p
Discussion in 'General Electronics Discussion' started by sheffladreece, Feb 24, 2015.
  1. sheffladreece
    sheffladreece
    22
    Jan 24, 2014
    I am currently attempting to communicate between two- nRF24L01 2.4GHz tranceivers using a ATMega328p with use of the USBtinyISP in C/C++ ... Is there any chance that anyone would have any coding regarding the setup/ communcation process or be able to offer any advice at all regarding this setup or coding of... I have limited experience, having only started coding and building electronics projects over the last 2 days so please bare with me if I do not understand elements of your replys. Thanks.
  2. (*steve*)
    25,501
    2,841
    Whilst I will keep my clothes on, I am happy to share some code.
    It will have to wait for quite a few hours though.
    First things:
    1 are you powering the device from 3.3v?
    2 are you using the small modules with 8 or10 pins? (beware that these have very different pinouts)
    3 are you using the arduino compiler?
    4 have you downloaded one of the available libraries and tried the demos they come with?
  3. (*steve*)
    25,501
    2,841
    My strong recommendation is to get the appropriate libraries (RF24, and maybe RF24Network) and go through the examples.
    Here is the simplest bit of code I have. It has the advantage of operating stand-alone, that is, it only requires a single NRF24L01. It is a fancy signal strength meter.
    Code:
      Combines RF24's scanner with the LCD output to make a standalone scanner
      The circuit:
     * LCD pin 1 (gnd) to gnd
     * LCD pin 2 (Vcc) to +5v
     * LCD pin 3 (VO) to wiper of 20k pot between Vcc and gnd (contrast adj)
     * LCD pin 4 (RS) to digital pin 7
     * LCD pin 5 (R/W) to gnd
     * LCD pin 6 (clock/enable) to digital pin 6
     * LCD pin 7 (D0) UNUSED
     * LCD pin 8 (D1) UNUSED
     * LCD pin 9 (D2) UNUSED
     * LCD pin 10 (D3) UNUSED
     * LCD pin 11 (D4) to digital pin 5
     * LCD pin 12 (D5) to digital pin 4
     * LCD pin 13 (D6) to digital pin 3
     * LCD pin 14 (D7) to digital pin 2
     http://www.arduino.cc/en/Tutorial/LiquidCrystal
     Example to detect interference on the various channels available.
     This is a good diagnostic tool to check whether you're picking a
     good channel for your application.
     Inspired by cpixip.
     See http://arduino.cc/forum/index.php/topic,54795.0.html
     The circuit:
     * nRF24L01 pin 1 gnd to gnd
     * nRF24L01 pin 2 Vcc tp 3v3
     * nRF24L01 pin 3 CE to 9
     * nRF24L01 pin 4 CSN to 10
     * nRF24L01 pin 5 SCK to 13
     * nRF24L01 pin 6 MOSI to 11
     * nRF24L01 pin 7 MISO to 12
     * nRF24L01 pin 8 IRQ UNUSED
    // include the library code:
    #include <LiquidCrystal.h>
    #include <SPI.h>
    #include "nRF24L01.h"
    #include "RF24.h"
    #include "printf.h"
    const
      uint8_t num_rows = 2;
      uint8_t num_cols = 16;
      uint8_t scan_wide = (num_rows - 1) * num_cols;
    // initialize the library with the numbers of the interface pins
    LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
    // Hardware configuration
    // Set up nRF24L01 radio on SPI bus plus pins 9 & 10
    RF24 radio(2,3);
    // Channel info
    const
      uint8_t num_channels = 128;
      uint8_t grp_size = num_channels / scan_wide;
      uint8_t values[num_channels];
    void setup() {
      // set up the LCD's number of columns and rows:
      lcd.begin(num_cols, num_rows);
      // Print a message to the LCD.
      lcd.print("nRF24L01 Scanner");
      radio.begin();
      radio.setAutoAck(false);
      // Get into standby mode
      radio.startListening();
      radio.stopListening();
    const int num_reps = 100;
    void loop() {
      // set the cursor to column 0, line 1
      // (note: line 1 is the second row, since counting begins with 0):
      lcd.setCursor(0, 1);
      // Clear measurement values
      memset(values,0,sizeof(values));
      // Scan all channels num_reps times
      int rep_counter = num_reps;
      while (rep_counter--)
      int i = num_channels;
      while (i--)
      // Select this channel
      radio.setChannel(i);
      // Listen for a little
      delayMicroseconds(128);
      // Did we get a carrier?
      if ( radio.testCarrier() )
      ++values[i];
      // Print out channel measurements, clamped to a single hex digit
      int i = 0;
      while ( i < num_channels )
      int group = 0;
      for ( int j=0; j < grp_size; j++)
      group += values[i];
      ++i;
      lcd.print(min(0xf,group), HEX);
