James Arthur wrote...
Winfield Hill wrote:
The circuit has three problems, all easily fixed. [...]
Here's a version that makes sure the inductor is bypassed at
RF frequencies, yet, per Win, avoids AM modulation of the bias
from power supply noise:
. .---------------------+----------+------- +Vcc
. | C1 | |
. R1 100n _|_ Rs
. 300mV --- 200mV
. | R3 | R4 |
. v\| .--/\/\--+--/\/\----+--------.
. |---, | 50mV 50mV | |
. /| | |/v | --- C2
. +-----+----| C| --- 1n
. | Q2 |\ C| L1 |
. R2. | C| ===
. 5mA .-. | GND
. etc | | R5 |
. | | | 1k +------------ out
. GND '-' |
. | Q1 |/
. RF IN------+-----------------|
. |\v
. GND
This circuit has two problems, easily fixed.
First, the 100mV drop across R3 and R4 is determined by the base
current of Q1, the exact value of which is unknown, and which can
change by a factor of say 3 over temperature, etc. So if the drop
varies from say 50 to 150mV, then the current-sense voltage will
vary from 250 to 150mV, which means we haven't done a very good
job of setting Q1's collector current. To solve this we need to
stabilize Q2's current. We can do this with a Q1 base-to-ground
resistor, R6 = Vbe/I, sized to draw say 3x more current than Q1's
base. We can hope this new resistor, R6, will have a higher value
than Q1's RF input impedance.
The second issue is loop stability. The loop gain is roughly
gm1*Rs, which is 40*0.2=8, times R6/(R3+R4) = 750mV/100mV=7.5,
for a DC gain of about 60. Capacitor C1 must provide a dominant
pole, reducing the loop gain to below unity before the occurrence
of a second pole. The second pole could be due to Rs C2, or due
to the input coupling capacitor, C3, with R6. Either way, C1
will probably need to be larger, likely an electrolytic.
Here's the new circuit:
. | C1 | |
. R1 elec _|_+ Rs
. 300mV --- 200mV
. | R3 | R4 |
. /| | |/v | --- C2
. | Q2 |\ C| L1 |
. R2. | C| ===
. 5mA .-. | GND
. etc | | R5 |
. | | | not too +------------ out
. GND '-' big |
. | Q1 |/
. RF IN ---||---+----+------------|
. C3 | |\v
. R6 |
. GND GND
I question the need for R5, which at any rate must not be too
big, or drop more than a few volts. I question it because Q2's
collector is a high-Z current-source output, most likely with a
low capacitance, much smaller than Q1's base. But, if it's not
too large, it won't hurt anything.
It could be an RFC.
