Now my Daewoo has its color back after off 15 hours?
Discussion in 'Electronic Repair' started by GGHS 1981, Jul 10, 2004.
  1. GGHS 1981
    GGHS 1981 Guest
    OK. I posted last night that my 8 month old Daewoo had changed its picture to
    lime greens and pinks. Today I went and turned it on after it had set off for
    about 15 hours, (just to make sure) and the picture is back to great color? Now
    I know I checked the color and tint controls more than once last night? I am
    not complaining...just scratching my head. It all happened right at the same
    time I pressed play on the VCR which was setting on top of the TV. Could there
    have been some kind of magnetic static discharge from the VCR that messed up
    the tube? Just seemed strange that the TV was working perfect up until I
    pressed play. Needless to say the VCR is no longer near the TV. Thanks for all
    your help on the post last night! Greg
  2. techforce
    techforce Guest
    Post a model Number ???
    to
    for
    color? Now
    am
    same
    there
    up
    all
  3. CJT
    CJT Guest
    Maybe you and I have encountered similar gremlins. I have a Sony VCR
    that served me well for several years. A couple of months ago the
    tuner suddenly stopped working -- it would still play tapes, but not
    record them anew (or even tune a station and present it to the RF out).
    I piddled with it over a couple of days and could NOT get it to work,
    no matter what I tried (tightening connections, reprogramming, etc. --
    but nothing involving opening the case).
    So I bought a new VCR, which I'm not terribly happy with because it
    has a sloppy transport compared to the Sony.
    Anyway, a couple of days ago I decided I'd try to fix the Sony. I
    plugged it in to reset the clock and configure it, and it worked
    perfectly the first time. I can't get it to fail. Go figure.
  4. Jerry G.
    Jerry G. Guest
    It is possible that something is intermittent in the set. You will soon see
    if the problem returns. These sets don't heal themselves.
    Jerry G. GLG Technologies GLG
    to
    for
    Now
    there
    all
  5. GGHS 1981
    GGHS 1981 Guest
    The model is DTQ27S4FC
  6. Jerry G.
    Jerry G. Guest
    The VCR is not the problem, and cannot do to any TV what you are describing!
    The set must have an intermittent fault. They do not heal by themselves.
    Jerry G.
    to
    for
    Now
    there
    all
  7. techforce
    techforce Guest
    I agree with the other Posts earlier that if you see blotches in the
    corners, then you have bad Degaussing Circuitry. It could merely be the
    Solder on the appropriate Circuitry need touching up near the posistor
    control on the Board. I have seen bulletins about bad solder on these in
    certain Daewoo Chassis.
    | to
    off
    | for
    | color? Now
    I
    | am
    | same
    | there
    messed
    | up
    for
    | all
  8. techforce
    techforce Guest
    And also yes, the CRT Will eventually lose its magnetic CHARGE Gradually if
    left off for many hours and the internal degausser is failed. Its basicly
    residual magnetism which the Degauss is suppose to clear on every power up
    ot the set.
    | picture
    | | to
    | off
    | | for
    | | color? Now
    night?
    | I
    | | am
    the
    | | same
    Could
    | | there
    | messed
    | | up
    I
    | for
    | | all
