Novice Design Help Please
Discussion in 'Electronic Design' started by HighFlight, Oct 28, 2003.
  1. HighFlight
    HighFlight Guest
    I've had some experience with electronics, and can solder quite well, but
    don't have the experience I need for this.
    Situation: My boat (12V) has a light control that is broke. I replaced the
    big components but it still doesn't work correctly. I think some traces are
    possibly bleeding because one button affects other circuits. Eventually,
    nothing works at all. The circuit is ground switching.
    Attempt #1: Prototype of a single circuit...I built the voltage regulator
    just as is on this board with a LM2930T-5. 4004 diode from power to source,
    22uf cap between ground and source pins, and a 220uf cap from output. Then
    I connected a 10Kohm resistor to that. Aft of resistor goes to a simple
    on/off switch instead
    of the flipflop/momentary switch logic. Output of switch goes to gate on
    15N05L mosfet.
    Source to mosfet is ground and drain goes out to fuse and out to the ground
    of the light circuit.
    Needless to say, it doesn't work and I'm sure it's because I'm an idiot.
    Plus, meter reads 10V aft of the capacitor...which confuses me right off the
    bat.
    Could someone possible make some suggestions. For all I know, I could
    simple use a surface mount on/off switch and get rid of everything else. I
    just don't know what they can take.
    Any help is GREATLY appreciated!
    Thanks.
    Jon
  2. N. Thornton
    N. Thornton Guest
    Yes, start with an overview of what you've got there, then tell us
    what the symptoms are... without this.......
    Regards, NT
