Not Working on Proteus ISIS
Discussion in 'General Electronics Discussion' started by aayush_vetwal, Jun 30, 2013.
  1. aayush_vetwal
    aayush_vetwal
    Jun 30, 2013
    Why doesn't the motor in this circuit run in Proteus ISIS?
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Perhaps the aerial is not picking up sufficient signal.
    Seriously, the motor power and type of motor is needed.
    What is the power supply.
    The IC contains a triac which indicates it might be an AC supply driving an AC motor. The led will not like this at all.
    Someone may be able to help if you can give some more information.
  3. Elecbegginner
    Elecbegginner
    103
    Mar 24, 2013
    The motor is a DC motor not AC according to isis .
  4. davenn
    davenn Moderator
    13,866
    1,958
    does the motor run if its directly across the PSU ?
    you still haven't told us what voltage the PSU is ?
    I assume you realise that this circuit doesn't do anything other than prove if the opto-coupler works or not ?
  5. CDRIVE
    4,960
    652
    May 8, 2012
    ISIS has quite a few motor models. What's the model you're using and what's the value of V+?
    Chris
