Not understanding C, DC, & Z flags from my homework?
Discussion in 'Electronics Homework Help' started by AndreeU17, Jul 16, 2016.
  1. AndreeU17
    AndreeU17
    42
    Apr 23, 2014
    I have a homework assignment i cant begin because i simply don't know how to approach it. I will post 1 question in hopes that someone will either help me solve it, provide information, outside sources or anything really.
    1) Find the value of the C, DC, and Z flags after the execution of the following code:
    MOVLW 0x85
    ADDLW 0x9F
    How do i go about that? If you need more information please let me know and ill provide more necessary information.
  2. NorthGuy
    NorthGuy
    53
    16
    Mar 24, 2016
    C flag is set when the result wouldn't fit in 8-bit register. Will (0x85 + 0x9f) fit in 8-bit register?
    DC is the same, but only for the low nibble. Will (0x5 + 0xf) fit in 4-bit nibble?
    Z is set when the result is zero, Is it?
    AndreeU17 likes this.
  3. Minder
    Minder
    3,016
    640
    Apr 24, 2015
    If you look in almost any Picmicro manual in the Instruction list section for any μp it explains exactly how an instruction affects the C,Z,DC etc.
    M.
  4. AndreeU17
    AndreeU17
    42
    Apr 23, 2014
    Okay that makes sense, however, what about the assembly code MOVLW and ADDLW? What does that in itself mean?
    I'm assuming that MOV is simply a move command that moves the address 0x85 into the LW. ADD then adds the 0x85 and 0x9F and the result will be placed within the LW? right?
  5. AndreeU17
    AndreeU17
    42
    Apr 23, 2014
    I don't have. This is all pulled out from the textbook and hw assignment.
  6. AndreeU17
    AndreeU17
    42
    Apr 23, 2014
    So correct me if im wrong but (0x85 + 0x9F = 0x124) and (0x5 + 0xf = 0x14), how do i know if it will fit into an 8-bit register or 4-bit nibble?
  7. Arouse1973
    Arouse1973 Adam
    5,164
    1,081
    Dec 18, 2013
    MOVLW mean move a literal value like say 10 into the working register. And ADDLW mean adding a value to what's in the working register. So you move 10 into the working register and add 10 to it to make 20.
    MOVLW b'1010' ; this is 10
    ADDLW b'1010' ; Add 10 to W makes 20
    Adam
  8. Minder
    Minder
    3,016
    640
    Apr 24, 2015
  9. NorthGuy
    NorthGuy
    53
    16
    Mar 24, 2016
    What is the biggest number that can fit into 8-bit register?
    What is the biggest number that can fit into 4-bit nibble?
