Not so easy led driving.
Discussion in 'Electronic Design' started by Fred Bartoli, Mar 29, 2007.
  1. Fred Bartoli
    Fred Bartoli Guest
    I've a situation where a string of 5 Leds (2mA) has to be powered from
    48V up to 1kV (HV safety indicators). That's about 20mW for the leds,
    and 2W heat under 1kV.
    The system ATM is a simple CC source (1BJT + 2 mosfets) but we now need
    as less heat generation as possible and a more compact design.
    The first idea was a resistive drop down to 50V or so, and from there
    have a small step down switcher current regulator providing the 2mA current.
    At 50% efficiency that would have been 0.8mA for 1.2W saving, and
    possibly more.
    ....but all the little switchers I could find either have huge current
    draw or low max input voltage, or something.
    Before I start rolling my own, which seems not so simple (first attempts
    show a serious lack of 'efficiency')
    I have to ask if I missed the good IC? (or idea)
  2. anything here
    http://www.powerint.com/appcircuits.htm
    martin
  3. colin
    colin Guest
    "Fred Bartoli"
    how about more leds in series using less current for the same light output ?
    Colin =^.^=
  4. Fred Bartoli
    Fred Bartoli Guest
    colin a écrit :
    One Led is also an opto (visual feed back for the operator and to the
    calculator too).
    And all that is doubled for redundancy :-(
  5. Fred Bartoli
    Fred Bartoli Guest
  6. James Arthur
    James Arthur Guest
    Must you power the LEDs from the 48-1kV? If not, you could make an
    isolated supply to power the LEDs, and a separate circuit to sense the
    high voltage: (warning: crude sketch)
    +15v (isolated)
    +HV >------. +--+--+
    | | LED1
    R1 | | :
    | | LEDn
    R2 Vref >-|/
    -HV>-------+----------+
    The isolated supply could be very simple, and unregulated.
    That would solve the heat problem, and could also be smaller than
    the space otherwise needed to dissipate 1-or-2 watts.
    Cheers,
    James Arthur
  7. Terry Given
    Terry Given Guest
    or just a self-oscillating flyback converter driving the LED, using a
    suitably high voltage device. just let it clag out naturally when Vin
    gets low enough.
    I built a 1W 100V - 1kVdc flyback with an emitter switched BU508 once.
    and it was harder to do than the 100W version.
    Cheers
    Terry
  8. joseph2k
    joseph2k Guest
    maybe buy one of these?
    http://tmt.stores.yahoo.net/grgtnovode.html
