NOT GATE Analog Circuit
Adarsh
Nov 11, 2017
Nov 11, 2017
How do I construct an analog circuit of a NOT GATE? I know how to construct a digital circuit using transistor and other things but the analog circuit is a bit tricky. I have also attached the required circuit diagram along with this post. I just don't understand how to practicalise the circuit. Please help.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Welcome to EP.
Logic operations are by nature digital.
Using a transistor ,which is an analog device by nature to create a NOT(invert) gate
is already an analog implementation.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Your sketch shows a battery powering a light bulb and a switch that shorts the battery to make lots of smoke. Why?
What do you want a NOT gate to do? It is simply a logic inverter, a high input produces a low output and a low input produces a high output. You can make an oscillator with two NOT gates if you want.
