Normally closed loop with relay trigger
Discussion in 'General Electronics Discussion' started by jbelectric777, Oct 4, 2015.
  1. jbelectric777
    jbelectric777
    32
    3
    Nov 29, 2012
    Hi Everyone, Been a while since my last visit, can you guys look at this attachment and tell me if it would work or not? All theory and self experience tells me yes, it would, but the program either isn't set up for slightly advanced circuits or I am totally wrong, the program is the free Yenka.
    Thanks in advance, you guys are awesome!
    Jim
  2. davenn
    davenn Moderator
    13,811
    1,945
    depends on what you are trying to achieve .... you haven't stated the circuit's purpose
    the top switch will activate the relay will give 15 V out on both relay contacts instead of just one
    what did you want the bottom pushbutton switch to do ?
    EDIT: since the top switch is in the on position, that infers the relay is activated and as such
    contacts are as shown ( the relay COMMON contact is connected to the NO contact )
    at the moment , pushing it will just turn the LED on and off .... it wont affect the relay operation
